امروز 4 اردیبهشت 1393, 04:37
ارسال مبحث جديد پاسخ به مبحث  [ 22 پست ]  برو به صفحه قبلي  1, 2, 3  بعدي
 موضوع پست: Re: »موتور چهار چرخ«
پستارسال شده در: 15 شهریور 1388, 08:54
پست ها : 162
محل سکونت: IR 62
نوع خودرو: PishroS135
Sports ATV/Polaris Sports ATV-Model:SW-SK3
تصوير
Product Description:
Engine type: 350cc , 6-5-4-3-2-1-0-R (ZS183FMP )
Cooling Air cool
Max horsepower:17KW
Max torque:24.0N.m
Bore*stroke:63.5mm
Max speed:90km/h
Climbing ability:30 degree
Ignition:C.D.I
Starting system:Electric start
Battery: 12V9Ah
Engine oil:1.5L
Gear oil:1.1L
Driveline :Chain drive
Driving wheel:Rear two wheels
Suspension:front/rear Double swing arms
Brakes:front disk/rear disk
Tire: a)Front:23x7.0-10 b)Rear:22x10.0-10
Wheelbase:1250mm
Product size: 1860x1270x1130mm
Height to seat :860mm
Min ground clearance:130mm
N.W./G.W.: 221KG/261KG
Packing size: 170*112*83cm
20ft: 12pcs / 40ft: 28pcs / 40HQ : 42pcs
پستارسال شده در: 15 شهریور 1388, 08:58
پست ها : 162
محل سکونت: IR 62
[size=150]ATV-Model:LA032-EEC[/size]
تصوير
Type:single cylinder,water cooling,4-stoke
Ignition mode:CDI
Compression proportion:9.2:1
Start mode:electric
Fuel tank capacity:4L
Transmission mode:chain
Power:9.5kW/7.500rpm
Max.torque:12.1N.m/6.000rpm
Min.ground clearance:100mm
Max.speed:80km/h
Power source:12V,9Ah
Transission:4 gears with one reverse gear,manual clutch
Cylinder size:63.5X62.2mm
Engine oil:0.9L
Lubrication:press splash
Desplacement:197ml
Parking trig:mechanical lock
Gas cylinder number:1
Front wheels:21x7-10
Rear wheels:20x10-10
Break type(F/R):disc/disc
Front hanging:double arm-swing
Rear hanging:integral
Product dimensions:1680x1115x1120mm
Carton dimensions:1480x850x880mm
Wheelbase:1160mm
Height of seats:850mm
Dry weight:167kg
Load capacity:105kg
Climbing degree:20
Min.turning radirs:2650mm
Max.number of riders:1
Conveyance:Qty/20'GP:30pcs
Qty/40'GP:44pcs
Qty/40'HQ:66pcs
Color:red/yellow/blue/green/camouflage
پستارسال شده در: 15 شهریور 1388, 09:04
پست ها : 162
محل سکونت: IR 62
250cc racing atv with EEC-Model:L-RA-250CC-3
تصوير
250cc EEC Racing ATV
1. engine type :250cc,4 storke, Water Cooled.
2. max torque : 17.5Nm/5000rpm
3. max power :13kw/7500rpm
4. ignition type :CDI
5. transmission :manual clutch,4-speed,reverse gear,chain
6.Brake (Front/Rear):Disc /Disc
7. starting system :Electric start
8. battery spec :12V,9AH
9. front suspension details :double A x swing arm,:air chamber shock absorbers
10. rear suspension details :divided ballonet absorber ??
11. front tire spec : 185 /30 - 14 rear tires spec : 270 /30
12. vehicle dimensions :202 x 113 x 97cm
13. wheel base :140cm
14. seat height from ground :64cm
15. ground clearance :80mm
16. load capacity :370kg
17. fuel tank capacity :8L
18. gross weight in carton :170kg
19. net weight :155kg ??
20. packing size:162x 83x 75cm
Qty/20' GP: 21units Qty/40' HQ: 42 units
Price Terms: FOB Ningbo
Payment Terms: 30%&70% by T/T (full container order )
Packing: 1pc/1carton
Lead Time: 20 workdays
Standards Certificate: EEC
Advantages: EEC Racing ATV,Semi-auto available 200/250cc water cooled. LCD speed meter,Double exhuast,12 inch alloy wheels,front big light,trun light,rearview mirror,Japanese Standard.
Color Available: red
blue
green
yellow
black
پستارسال شده در: 15 شهریور 1388, 09:08
پست ها : 162
محل سکونت: IR 62
300cc ATV Chain Drive Air-cooled Big Quad Bike 4-Stroke Utility Vehicle-Model:FTA300-19
[img]
http://img5.imagebanana.com/img/r81i64x ... d_Big_.jpg[/img]
Specifications:
1) Dimensions(LxWxH):1800x1160x1120mm
2) Wheelbase:1150mm
3) Engine type:300cc,single cylinder air-Cooling,4-stroke
4) Start mode:electric
5) Power:9.5kW/7,500rpm
6) Max.torque:12.1N.m/6,500rpm
7) Max.speed:??5km/h
8) Min.ground clearance:120mm
9) Dry weight:195kgs
10) Transmission mode:chain
11) Break type(F/R):disc/disc
12) Power source:12V,9A
13) Climbing degree:20 degrees
14) Fuel tank capacity12L
15) Front hanging:double arm-swing
16) Rear hanging:integral
17) Tires:
a)Front wheels:21x7-10
b)Rear wheels:22x10-10
18) Cylinder size:78 x 61.2mm
19) Transmission:
20) Min.turning radius:2,650mm
21) Parking trig:mechanical lock
22) Ignition mode:CDI
23) Load capacity:150kg
24) Gas cylinder number:1
25) Max.number of riders:1
26) Lubrication: press splash
27) Compression proportion:9.2:1
30) Product dimensions (L x W x H): 1,680 x 1,115 x 1,120mm
Outer packing:
Carton dimensions:1,480 x 850 x 880mm
Conveyance:
Qty/20' GP: 20 units
Qty/40' GP: 44 units
Qty/40' HQ: 66 units
پستارسال شده در: 15 شهریور 1388, 13:51
پست ها : 825
محل سکونت: تهران
نوع خودرو: Bajaj Avenger
دوست عزيز من امروز متوجه شدم عكسهايي كه شما همراه با توضيحات قرار ميديد همون موتورهاي AVT هستند،
اگر منظورتون همون موتورها هست بايد عرض كنم تاپيك مربوطه وجود داشت اما اگر منظورتون UTV هست يه لطفي كنيد در مورد تفاوتش با AVT توضيحاتي هم بديد.
تصوير
تصوير
تصوير
تصوير
تصويرتصوير
تصوير
تصوير
تصوير
پستارسال شده در: 15 شهریور 1388, 14:10
خودروساز
پست ها : 4310
محل سکونت: کرج-مهرشهر
نوع خودرو: Azera_Ford_Gen2
Mohammad Karol نوشته است:
ArM@n نوشته است:
Arsalan Ghozmit نوشته است:
آرمان جان تاپیک داریم در موردش:
atv-t20474.html
سلا ارسلان جان
من این تاپیکو برای نمایش عکس و بررسی انواع مدل ها زدم.
موفق باشید :eek:
FWD Sucks , Monkey Nuts !
تصوير
پستارسال شده در: 15 شهریور 1388, 16:21
پست ها : 825
محل سکونت: تهران
ArM@n نوشته است:
atv-t20474.html
سلا ارسلان جان
موفق باشید :eek:
تازه اگر هم این تاپیک برای نمایش عکس و بررسی انواع مدل ها باشه بهتره تو تاپيك خودش باشه.
هر چيزي طبق قانون و در تاپيك مربوطه ي خودش :cool:
پستارسال شده در: 15 شهریور 1388, 19:49
پست ها : 162
محل سکونت: IR 62
سلام دوست من.
راستش من تو این تاپیک سعی میکنم عکس و مشخصات از تمام برند هایی که این نوع موتور رو تولید میکنند بزارم.
حالا چه atvو چه دیگر برند ها.
اما اون تاپیکی که شما می فرمایید مخصوص موتور های چهارچرخ برند atv میباشد.
به هر حال اگر اشتباه کردم,عذر میخوام.
:eek:
پستارسال شده در: 15 شهریور 1388, 20:06
پست ها : 825
محل سکونت: تهران
ArM@n نوشته است:
سلام دوست من.
:eek:
نه دوست عزيز،
اصلا هم اشتباه نكرديد،
فقط بنده ميخواستم توجيه بشم كه در اين تاپيك كدوم يكي از اين موتورها بررسي ميشه كه توجيه شدم،
اگر بنده جسارتي كردم من رو ببخشيد،
در ضمن لطفا در مورد تفاوتهاي اي تي وي و يو تي وي هم توضيحاتي رو بديد ممنون ميشم.
پستارسال شده در: 15 شهریور 1388, 00:40
آفرودر
پست ها : 1551
نوع خودرو: Citroen C5-Landrover
ArM@n نوشته است:
سلام دوست من.
:eek:
برادر آرمان، حتما میدونی که ATV یه برند نیست، ATV یا همون QUAD اصولا به موتورسیکلتی با چهار چرخ و برای همه نوع مسیر گفته میشه،
http://en.wikipedia.org/wiki/All-terrain_vehicle
ALL Terrain VehicLe رو توی گوگل یه سرچی میکردی می دیدی که از یاماها و سوزوکی و پولاریس، تا چینی های عزیز همگی ATV تولید میکنند، چیزی که شما گفتی مثل این بود که به SUV بگی یه برند ماشین...
cron
tt.tuningtalk.com
